Constant Bluetooth Connection Request from unknown device
(Topic created on: 02-04-2025 07:50 PM)
slowkultur
EDIT....Semi-Solved!
Enter Service Menu via:
- turn off tv
- press info, menu, mute, power
Then MRT & Engineer options to disable BT functions. The former is shown as a BT address, selecting UP arrow lets you disable it.
Side-effect: now Bluetooth is completely disabled. Not an issue for me. Other side-effect is the Smart-Remote no longer responds. But the classic Remote (IR) still does.
Hi,
My JU7090 (48") has been fine until suddenly I got constant Bluetooth Connection Requests from an unknown device, called C39S.
Despite denying the Request every few seconds it keeps coming up.  I go into Bluetooth Settings and unpair then delete it.  Seconds later it automatically pairs again!  And this popup message then keeps coming up. In the settings I've set to OFF to connect any new device.
Ran the Setup again.  Have updated Firmware & Software.
I can't find a way to delete or block this obnoxious device.  Can't even find a way to disable bluetooth altogether.  Seriously the only way to stop the pop-up from coming every few seconds is to accept it....then I have no more sound!
10 REPLIES 10
ProtarArk77
Hi
spectro8787
Helping Hand
You should not accept
spectro8787
Helping Hand
Hi welcome to Samsung member \(^-^)/
slowkultur
"Despite denying the Request every few seconds it keeps coming up. "
spectro8787
Helping Hand
Just ignore it
spectro8787
Helping Hand
It could be a virus or a hacker
slowkultur
It's better if you just stop posting.
slowkultur
Where are the normal replies??
spectro8787
Helping Hand
What did I do
