Filmmaker mode
(Topic created on: 16-09-2022 06:06 PM)
Dinodzz
I need the settings numbers on filmmaker mode. When i switch to film and back to filmmaker mode its exactly the same.
2 REPLIES 2
AndrewL
@Dinodzz: Filmmaker Mode reduces the amount of post processing applied by the TV, so the film you're watching looks as it was intended to by the filmmaker (hence the name). The effect it has will depend on the content you're viewing, however both Movie and Filmmaker modes will typically darken the image, which may be why it seems like there's not much difference when you switch between the two.
Dinodzz
ok i see, but are they both supposed to be at 32 brightness as standard?
