BBC iPlayer
(Topic created on: 09-11-2021 04:22 PM)
jfbuk
Hi,
The BBC iPlayer is not re-sizing correctly when I scroll through the menu screens, see attached pics.
I cannot scroll back to the top of the app to use to the top bar menu after scrolling down which is very frustrating
TV Model:QN94AA50
Software Version : T-NKM2DEUC-1805.4BT-5
The app is up to date and this does not happen on other devices so its Samsung TV specific.
I expect Samsung to advise rather than just directing me to the BBC as its only happening on my Samsung TV
John
StephK1
Troubleshooter
Hey @jfbuk! This issue with iPlayer is currently being looked into behind the scenes. For now, to avoid being unable to access the Home bar, please either load the app and then wait a few seconds before navigating, or go to Settings within the iPlayer app and select "Try new features in BBC iPlayer Beta", as the Beta version does not have this issue. Hope this helps 🙂
7 REPLIES 7
nowdeleted
Big Cheese
Have you looked at the TV settings, to see what the default aspect settings are set at ?
jfbuk
Yes. Its not  a playback issue.
It only happens with the iPlayer menu screens that's why I was specific about where it happens.
JAMES4578
Samsung Members Star ★★★
Hi @jfbuk  You have the latest software.    Go to Home - Settings -Picture - Picture Size Settings - Zoom and Position to see if you can sort it out.  If not see if you can reinstall iplayer,   if still issues I would advise that you hold and press the power button for 5 seconds or until Tv reboots and/or unplug from the mains for around 5 minutes. Another idea is a factory reset.
jfbuk
I repeat that this is not a content playback problem so why would altering the picture size settings help !
StephK1
Troubleshooter
jfbuk
Thank-You Stephk1
JAMES4578
@jfbuk Did not think adjusting picture settings would help, was more a process of elimination (even if no issue with other apps)    Should have asked which version of iplayer you were using,  hopefully no issue with the Beta version.  This may be mainly affecting   more recent models.
