27-07-2023 09:18 AM
How do you set up Alexa or Bitby, the General - Voice menu does not take you to Voice Assist, thank you
27-07-2023 02:56 PM
@Devongirl1: It should be possible to access your Voice Assistant settings by pressing the Home button on your remote > Menu > Settings > All Settings > General & Privacy > Voice > Voice Assistant > Select which Voice Assistant you would like to control your TV.
If you're unable to locate Voice Assistant via the steps above, please can you provide a photograph of the menu options, so I'm able to gain a better understanding of what you're seeing?
14-01-2024 09:55 PM
Hello
I don't see the voice option. Please advise
15-01-2024 12:30 PM
@Confused_098: That's odd, as this is the path that is provided in the user manual, although it does state that the feature may not be available depending on your model or geographical area. As a workaround, try pressing and holding the microphone button at the top of your Smart Remote, and a pop-up should appear which prompts you to set up Voice Assistant. If the issue persists, then it is likely that the feature is not available on your TV.
15-01-2024 03:48 PM
I get the feeling I don't have this in my tv. I'm based in UK and both my controls doesn't have the microphone button at all
22-05-2024 10:42 AM - last edited 22-05-2024 10:43 AM
22-05-2024 11:34 AM
The CU7100 series doesn't have any built-in Voice Assistants such as Bixby or Alexa. It can work alongside AI speakers such as Alexa Echo. All you would need to do is add the SmartThings skill to your Amazon app on your phone.
