14-02-2025 11:30 AM
Hi,
I have owned a 55” QN95A Neo QLED 4K HDR Smart TV (2021) since 2021 and have been trying to use a USB device to record and pause live TV.
For a while, a standard USB pen drive worked well, but all of a sudden, my TV was saying "no USB detected". So I found an SSD drive that I was not using and bought a suitable SSD enclosure that had a mains power supply.
My TV will detect the SSD and record and pause TV, etc, but if I turn off my TV it will not record anything whilst the TV is not turned on, and when I turn my TV back on, the TV says, "no USB detected". If I restart the USB enclosure, it works fine, but when I turn off my TV, I have the same situation.
Does anyone have any recommendations? Thanks in advance!
14-02-2025 02:36 PM - last edited 14-02-2025 02:38 PM
Hey, sounds like your TV is cutting power to the USB port when it shuts down. One workaround might be to use a powered USB hub that stays on independently of the TV—this could keep your SSD active even when the TV's off. Alternatively, check if there's a "USB Always On" setting in your TV's menu. If not, a hub is your best bet to maintain a constant power supply for your recording setup. Hope that helps!
14-02-2025 03:07 PM
Hi, thanks for your response. As I said, "So I found an SSD drive that I was not using and bought a suitable SSD enclosure that had a mains power supply". Is that what you meant? If yes, I have already tried that 😞
23-02-2025 11:48 AM
Hi
Only thing I can think of is to reset TV to factory settings and reformat your HDD and connect to USB port. I believe there is a powered USB port.
