S90D / S93D UHD Picture Judder
(Topic created on: 14-02-2025 09:34 AM)
Int3rceptor
Watching the darts on Sky Sport UHD last night and after every replay, the picture judders until the camera angle is changed.   This also occasionally happens on football in UDH
All motion settings on my TV are turned off.
I noticed that this only occurs when the Contrast Enhancer is set to Low or Medium.  If I turn that up to High then the issue doesn't happen but the picture is not to my liking.
It also doesn't happen if Clear Motion is turned on but I hate that mode!
Is there anywhere I can report this as a bug as I cannot see why setting the Contrast Enhancer to High would resolve a problem like this.
thanks
6 REPLIES 6
Ginga_p
Hotshot
Have you turned on the judder reduction in the sky audio visual settings
G G
Int3rceptor
Yes, I have tried the Judder setting in the Sky Q menu but it makes no difference.  I think that only works for Apps.
JAMES4578
Samsung Members Star ★★
Yes the Judder setting on Skyq is specifically for Apps. Motion setting needs to be turned on for Judder reduction via Tv but can be set to low level. However this mode does not always appeal.
Know with this sort of issue some have found it helps if the Eco options and Intelligence modes are not activated.
Otherwise could try experimenting with Picture Settings but no guarantee.
A guide here https://www.rtings.com/tv/reviews/samsung/s90d-s90dd-oled-qd-oled/settings
Int3rceptor
Thank you - I will have a play.
Worst case scenario is I leave the Contrast Enhancer set to high - not ideal but the image quality doesn’t suffer too badly.
It’s strange that setting it to High fixes it but Low doesn’t - I wonder what additional processing is going on to cause this.
Ginga_p
Hotshot
Are you using sky q or a sky puck
G G
Int3rceptor
it’s Sky Q.
After researching more, it’s apparently a widespread issue and occurs mainly during sports after a slow motion replay.
The TV can’t handle the slow lotion so tries to compensate and when the footage reverts to normal speed, there is judder for 5 to 10 seconds until it sorts itself out.
There is talk that new firmware 1301 reduces this issue (not 100%) but as it’s not available in Europe yet I can’t check this.
