19-04-2024 06:03 PM
These bars persist across all apps, a Chromecast and the standard TV function. The TV has been power cycled, all devices unplugged and gone through a factory reset. The bars (as can be seen in the video) appear to change thickness depending on the brightness of the screen. I have also tried disabling settings such as contrast enhancer, all the picture clarity settings (judder reduction etc.) and adaptive brightness. The fault appears at both low and high brightness and on all of the R, G and B channels when isolated.
Any help would be appreciated
Model Number: QE43Q60AAUXXU
Software Version: T-NKLADEUC-2210.1, BT-S
19-04-2024 09:42 PM
19-04-2024 11:26 PM
It happens irrespective of auto picture clarity being switched on and on every single picture mode (although the bars are even wider in dynamic, whereas the video was shot on standard picture mode). Strangely, the bars completely disappear on all the test images & test video in the diagnostic menu and everything looks great. I feel like it may be a software glitch in the newest firmware update - something to do with the smart menu?
20-04-2024 02:23 AM
20-04-2024 10:22 AM - last edited 20-04-2024 10:24 AM
20-04-2024 12:25 PM - last edited 20-04-2024 12:25 PM
All external devices have been unplugged. The TV has been factory reset. It does not show on the diagnostics samples for video or picture. On further investigation, it is definitely a software bug in the menu UI that is overlaying all sources. When in the menu and clicking between options those same bars follow the currently selected (highlighted) option. Samsung do not appear to give any way to downgrade your firmware version either.
a month ago
Replying to note that I also have this problem with a 43" Q60C -- exactly the same symptoms. Let's hope Samsung gives us a fix if it is indeed a software problem. It's very noticeable and distracting/annoying when watching pretty much anything.
