Samsung Oven water drain light
(Topic created on: 04-12-2020 11:44 PM)
Sherry4
The water drain light on my samsung micro/oven combo started flashing and there is no water in the reservoir.  Samsung support told me to turn off the breaker for 5 minutes and it would reset, that did not work.  Any idea?
4 REPLIES 4
Pocoman246
Is this still happening to you? It is driving me nuts. Let me know if you found a solution
SamKitUser
Water Drain icon started flashing yesterday after kitchen cleaning.  Don't know why.  Did we touch something?
Nothing in the User Manual.  Samsung - please add this!
It is a wall oven, so rather than go to basement to try the power cycle, I set it to bake on low temperature, just to see what would happen.  Indicator continued to blink while heating.  After it reached 175 deg, pressed Oven Off.
A new input key label "Drain" appeared under the main display.  Pressed it, heard a pump turn on for a few seconds.  When the pump stopped, the Water Drain icon turned off as well.
WesamK
This might be way too late as answer to this concern. I searched the net, and youtubes, but could only find the details in this usar manual:
https://www.vieffetrade.eu/shop/pdf_articoli/Samsung/506680.pdf
Let me know if you would like to list the details here
wmotley
Worked great!  Thanks for sharing!!
