07-10-2020 10:56 AM in
Home AppliancesHi there,
I have just tested out my new DV80M50103X heat pump dryer for the first time.
It's dried the towels on the towel setting absolutely fine, but I couldn't help but notice during the cycle there is what feels like a constant flow of warm, damp air coming out of the drum during the cycle (only from the side the door opening handle is on). The seal looks to be fitted in correctly and there is no obvious gap I can see.
Is this normal or have I got a faulty machine as I thought all the heat was supposed to be trapped and condensed in the machine? I don't want want my small utility room to be filled with condensation, which was one of the reasons for purchasing a lower temperature heat pump machine.
Thank you in advance!
09-10-2020 10:49 AM in
Home AppliancesAny ideas? Does anyone else here have a Samsung heat pump dryer where they can let me know if moist air can be felt coming out of the door?
Thanks!
31-12-2020 12:07 AM in
Home AppliancesHi David, I am having the same problem. Did you find a solution ?
07-03-2021 06:25 PM in
Home Appliances24-09-2022 12:35 PM in
Home Appliances24-09-2022 01:17 PM - last edited 24-09-2022 01:34 PM ) in
Home Appliancesclean out all the dust and then try and close the gap up with white (or black) silicone sealant to stop the dust getting back in maybe ?
