Go to solution Solved
S25 ultra heating and battery draining very fast
(Topic created on: 02-03-2025 09:29 AM)
Jannatlopa
After the February patch update, suddenly my s25 ultra is heating too much and battery draining too fast.  the battery is draining quickly even when I am not using it. Any one else facing the same issue? Any suggestions to improve the situation? even my battery usage is not showing any unusual usage.
Go to solution
38 REPLIES 38
Shivanand Anchalkar
Seriously, no matter what I do, the battery drains 2% every 5 minutes! Screen's at 60FPS, resolution's FHD+, apps are sleeping, junk's uninstalled, no live wallpaper, dark mode's on, screen times out after 15 seconds, and I'm using the official 45W Samsung charger. Before the February update, it lasted a day and four hours! Now it's only 12-13 hours.
Hope906
Maybe this will be useful to someone. Yesterday, I tried the method mentioned above. When my phone got hot and the battery was down to a few percent, I turned it off, let it cool down completely, and then charged it while it was still off.
In the morning, I turned it on, and the battery lasted the whole day just like before the update, without overheating. So far, it’s been a day, and I hope the overheating won’t come back and that this actually helped.
Members_eB4ls9e
Hello, I have an issue which get worse
Samsung galaxy s25 ultra which battery dies in 5 -6 hours
What to do, why this happen, will they fix it ?
Now is 50% down for less than 3 hours in  which is used not all the time
Members_eB4ls9e
Yes but I didn't pay 1500 euro to put power safe mode on brand new flagman phone
Jannatlopa
You can follow what I did to fix the issue. my issue is resolved now.
Jannatlopa
Hi! You can follow what I did to fix the issue. my issue is resolved now.
Jannatlopa
You won't have to keep on the power save mode if the issue is resolved. You can follow mine.
Jannatlopa
You can follow what I did to fix the issue. Hope yours will be fixed too!
Jannatlopa
Hi, yoi can follow what I did. My issue is solved now. Hope for the best
Shivanand Anchalkar
So, I figured it out! Remember that crazy battery drain after playing Asphalt Legends Unite? It was draining super fast, so I had to use power saving mode for a couple of hours. After that, the problem went away – the battery's fine now, even without power saving mode or any tweaks. Looks like a bug in the game; it probably over-clocked the processor and never went back to normal. That's gotta be why the battery died so fast.
