Go to solution Solved
S25 ultra heating and battery draining very fast
(Topic created on: 02-03-2025 09:29 AM)
Jannatlopa
After the February patch update, suddenly my s25 ultra is heating too much and battery draining too fast.  the battery is draining quickly even when I am not using it. Any one else facing the same issue? Any suggestions to improve the situation? even my battery usage is not showing any unusual usage.
Go to solution
38 REPLIES 38
ItsYeBoiRehan
Ive had the same issue and my battery health is perfectly fine. Seems like the update has messed something up
Jannatlopa
Thank you all for your help and suggestions. I guess I have got an solution. I am sharing what i have done for those who are facing the same issue.
step 1: I have added most of the apps in deep sleep list. except gmail and other important apps from which i need instant notification.
Step 2: I turned off my device. Then kept it aside to cool it down and then charged it to 95%. All should be done in power off state.
Step 3: turned on my device with the name of Almighty Allah and put it on power save mode just for safety.
After that, i have found it ok till now. You can try this too.
Jannatlopa
moe192
Voyager
Mines fine nothings wrong with it. Get excellent battery life
tabino1auntie
Navigator
I had a couple of days of the battery draining after I done the update but it seems to have resolved its self now hopefully
Pranav Singla
Exactly the same Issue, only able to survive the day as I have my second phone as S25 Plus, hoping this faulty update doesn't come to my second phone!
Samsung needs to fix this ASAP
nnikor
Same problem here too, hopefully Samsung addresses this and releases a fix soon
hhx89uk
Same here ,this phones battery are bad and Samsung will not do nothing about it!!! My s23 ultra had double the battery life with same apps installed same usage or more !
Clà1
Same problem although I deactivate all settings suggested that could drain the battery. At this moment I prefer not to do a factory reset since I had difficulty in restore whatsapp backup
Hope906
I have the same issue after the update. Before the update, the battery lasted very well, even better than my previous S24 Ultra. But after the update, the phone overheats, and the battery drains very quickly. I hope this will be fixed in the next updates.
