S24 ultra battery drain issue
(Topic created on: 01-04-2024 08:20 PM)
SIMMAR
I'm facing battery drain issues on my s24 ultra ..is anyone facing this issue? If anyone have idea how to solve this issue please let me know..
9 REPLIES 9
lmmartinsn
Pioneer
As far as I know, the phone will need few days or weeks to learn you usage skills so then, can define the battery perimeters.
You might notice a slightly increasing of hotness but with time, will eventually settle on its own
Piper123
Samsung Members Star ★
There have been multiple posts on this over the last couple of days. It would be really helpful if users did a search first.
How long have you had your device?
I am not employed by Samsung nor do I receive any remuneration as a Samsung Members Star.
My device is an S25 Ultra.
SIMMAR
I'm using s24 ultra from last 2 months sometimes battery give good backup but sometime battery give very poor performance..
SIMMAR
But I'm using s24 ultra from last two month is it still in learning phase?🤷
lmmartinsn
Pioneer
SIIMMAA, every device is different and it all depends on the usage criteria you applying.
Yet Samsung didn't address this "issue" on right path but we keep a tracking and closer look up upon the community
mieloncom
Voyager
You can try wiping the cache after the last update.
SIMMAR
But this is the issue which Samsung should be adress ..Are you Samsung developer team member ?
SIMMAR
Ok I I'll try
arunmathews
After the recent update on march 2024,I am also facing the battery draining issue...Any one have idea about or any one facing similar problems??
