S24 plus Battery drain
(Topic created on: 13-02-2024 04:28 PM)
Sabclips
Navigator
Anyone realise how quickly the S24plus (exynos 2400 variant) drains. I upgraded from an S8 plus which is about 6years old and strangely my new S24 plus on mobile data barely outperforms the 6 year old phone during usage. The only time it siginificantly does, is during ideal time where my S24 plus loses about 1% every hour compared to my S8 plus losing about 2-3%. It's unbelievable how apps such as Google maps and camera etc (which are supposed to be optimised) drains the battery so quickly as if they are not.
23 REPLIES 23
cloudh
I've been having the same problem for 1-2 days. location off, bluetooth off. I don't play many games. I usually hang out on social media but the battery is constantly decreasing. I don't understand why the problem occurs. It wasn't like this at first. any solution?
cloudh
i do wipe cache but how can we do repair apps?
GoanGeek
Samsung Members Star ★
Same menu at the bottom
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
cloudh
i can't find it, which menu?
GoanGeek
When you do a phone Wipe Cache it's there at the bottom REPAIR APPS.
cloudh
Unfortunately, I do not have an option called repair apps in that menu. There are only these.
GoanGeek
Did they remove it 😲
You can try downloading Good guardians from galaxy store and run the app booster app within it as well.
cloudh
There is no such application in the Store. I guess it is not supported in our country ahahaha
GoanGeek
Which country you from?
It's.in Samsung store not Google play.
https://eu.community.samsung.com/t5/galaxy-s24-series/samsung-apps-you-need-to-download/td-p/9194472...
cloudh
Turkey. Unfortunately, the app is not supported by phone or country.
