Go to solution Solved
Issues with sound through USB-C port
(Topic created on: 22-07-2023 08:47 PM)
gublersghost
I've been having trouble for a while now with my S23 Ultra. Charges absolutely fine through the USB-C port, but listening to music and videos is when the issue occurs. It only happens intermittently through wired headphones and through a cable in the car (USB-C to aux). Sound will either cut out altogether, which is the more common occurrence, or will start crackling. I've tried multiple headphones and multiple cables in the car. Any suggestions?
Go to solution
21 REPLIES 21
Jogibaer
I'm experiencing the same problem. Die original Samsung USB-C to audio jack adapter is worse concerning the stability of playing music, than a cheap adapter. However, I hear a lot of crackling and distorition on both, but the Samsung on some point just stops playing music althoug the player time keeps running. It's really the biggest mistake ever to cancel the audio jack on smartphones. These f**** USB-C adapters are bad, unreliable and produce more electric garbage. This USB-C only development is a step backwards. -.-
Dashiini
I did the following on top, but i am still not able to connect my headphone
