Go to solution Solved
Issues with sound through USB-C port
(Topic created on: 22-07-2023 08:47 PM)
gublersghost
I've been having trouble for a while now with my S23 Ultra. Charges absolutely fine through the USB-C port, but listening to music and videos is when the issue occurs. It only happens intermittently through wired headphones and through a cable in the car (USB-C to aux). Sound will either cut out altogether, which is the more common occurrence, or will start crackling. I've tried multiple headphones and multiple cables in the car. Any suggestions?
Go to solution
21 REPLIES 21
jb997
What if "force stop" is already grey?
Monkeyjim24
Andrew all the settings have changed since the update? What do I need to do now the OS is on Android 14? Best wishes Grant.
DKFredrickson
Followed your steps, didn't work for me, will need to track down another set of usb-c earbuds to check for sudden failure of my current earbuds, THX
Members_d68dAB0
Syalm
What should I do if this happens on an S22? When using a USB-C to aux to listen to music in the car, it defaults to the headphones mode. This limits the volume range massively, and I can't even switch via media output. Please help.
niktelaa
I have a samsung s10e i cannot find the usbsettings app? is there a different way to find it for older phones?
Lilydandelion
Wow! Thanks a bunch for your great tip! It worked like magic!
Banana flopper
So I tried this and I force stopped it and everything but when I plug back in the dingle and try to listen to music, it only plays through the loud speaker, so you have any help? (If it helps im on a s24+)
fylim
Solution didn't work for my S21 Plus. USB notification shows connected though but audio is not playing through Samsung USB C Earbuds
lukxs
Didn't work for me on my S24 but to be fair this is a $2 USB c to aux adapter lol
