3 weeks ago
3 weeks ago
Hi @Chris741.
I'd suggest that you clear the data from the USB Settings app. Open Settings > Apps > Tap on the sort by icon next to ‘Your apps’ > Show system apps > Tap on the USB Settings app > Storage > Clear data.
Also, make sure that there are no obstructions in your charger port and that you're using a genuine Samsung charger. You may try another charger to see if the same issue persists.
3 weeks ago
3 weeks ago
For me it says "Connected super fast charger" but speeds are slow in accubattery it goes in minus than around 2.1. Sometimes it stuck and don't charge at all or from super fast go to normal.
3 weeks ago
3 weeks ago
3 weeks ago
3 weeks ago
3 weeks ago
3 weeks ago
