My phone is charging I have to use a portable charger and a particular lead.
(Topic created on: 02-06-2024 03:27 PM)
DanielWestbrook
Voyager
My mobile phone Samsung galaxy a52s 5g.
Won't charge I brought around 10 leads in the last 2 months.
I have to use a portable charger and a particular small lead which is far to small.
Any idea what is causing this, this is so frustrating guys.??????
1 REPLY 1
AndrewL
@DanielWestbrook: Do you have access to a home computer? If so, try using the USB cable that came packaged with your Galaxy A52s 5G, and connect the device to your computer to see if you're able to establish a charge in this manner. If not, please check the USB port of the phone for any dust or debris, and clear anything you find with a soft bristled brush. If the issue persists, head to the Samsung Members app > Support > Phone diagnostics > Cable charging. Do you see an 'Action required' notification in the summary at the end of the test?
