Samsung Odyssey G7 auto switch inputs doesn't work and takes a long time to turn on. Samsung please fix...
(Topic created on: 17-05-2022 01:33 PM)
LaurenceGough
Pioneer
This monitor still cannot auto switch between inputs, it's a known issue with 100s complaining. As of the latest firmware 1014.1 it still is an issue, you have to manually switch between. This is a feature that £50 monitors can do, but this one over £550 can't.
This monitor also takes a long time to startup, my PC has started long before it's finished turning on.
Model# LC32G73TQSUXEN but it happens with all of the Odyssey G7s and I believe even the G9s.
These are meant to be flagship monitors Samsung....
Edit:
I got a Dell Alienware monitor instead, much better. I wouldn't bother buying Samsung again as they cannot even do simple features on their flagship monitors.
Samsung hardware, always great but the software continuously lets it down.
32 REPLIES 32
tunahulk
Appreciated but I have a Mac
Demonee
Solution: I had the same problem.  I found that in the last update the Autorun Samsung TV Plus option is enabled by default which stop the smart switch input function. Go into Settings > General & Privacy > Start Screen Options and uncheck the Autorun Samsung TV Plus.
TEK6
Same issue, monitor refuses to switch sources, sometimes it dont wants to turn on when i power my pc, just stays in standby then auto turn off. Never ever buy Samsung monitor.
