02-11-2020 06:04 PM
- Mute
- Highlight
I have HW T450 soundbar which I am very pleased with but it has deep and strange background interference noise on it. I tried woofer level set to -12 but doesn't matter, firmware update (v1033) or change location didn't work.
Anyone had the same experience and is there a fix?
Sinan
Solved! Go to Solution.
- Tags:
- T450
25-01-2021 04:37 PM
- Mute
- Highlight
Thanks God I am such a great procrastinator and did not report my issue earlier. Today I have updated the firmware (ver1043) and the problem disappeared Thank you guys!
04-11-2020 12:11 AM
- Mute
- Highlight
Same issue...
I’ve tried everything, only the unplugging solved the problem. 😂
04-11-2020 08:19 AM
- Mute
- Highlight
Yess that's a good solution 😁 I started a topic local samsung community at my country too and official moderator says it needs check by Samsung authorized service center so I called service. They will come in a few days. Let's see what they say 😁
14-11-2020 09:09 AM
- Mute
- Highlight
And what they said? Wondering cuz I've got the same problem
14-11-2020 11:54 AM
- Mute
- Highlight
They said the subwoofer needs change so I'm waiting for it. However, some people say the problem continues despite the change.
14-11-2020 03:10 PM
- Mute
- Highlight
So they gonna replace your subwoofer for a brand new one?
14-11-2020 04:11 PM
- Mute
- Highlight
Yes.
27-11-2020 07:50 AM
- Mute
- Highlight
Hi everyone,
Customer services replaced my subwoofer for a new one but it has the same problem. Latest firmware update(v1038) did not work. I am gonna request a refund.
14-12-2020 10:46 AM
- Mute
- Highlight
Hello. I have the same soundbar and i have the same problem. I upgraded software to the latest version but it dosesn't help. My local service stated that this is normal with such cheap equipment.
15-12-2020 05:52 PM
- Mute
- Highlight
The refund was made to me. I recommend that you also request a refund because this is not normal.
