27-03-2022 02:26 AM in
WearablesMy Samsung Galaxy S8 keeps disconnecting the Bluetooth to my Sony Headphones while I'm playing music, whenever my Samsung Galaxy Smartwatch 4 LTE is in range.
27-03-2022 01:37 PM in
Wearables@ergjam: The Galaxy S8 can only establish a single Bluetooth connection at a time, so the Galaxy Watch 4 may be auto connecting to your phone, and causing your headphones to disconnect. On your Galaxy Watch 4, head to Settings > Connections > Bluetooth, and disable this feature while you're not using it, and you should find that this resolves the issue.
29-03-2022 07:52 AM in
WearablesHi Andrew, There's actually a setting in Bluetooth that allows more than one Bluetooth device. Settings-Bluetooth-Advance-Dual Audio.
