I lost my Samsung Gear S3
(Topic created on: 08-07-2019 12:20 PM)
Fari5
Hello guys. I lost my Samsung Gear S3. Is there any chance I can locate it? I was only connecting that device to my Samsung Galaxy S9+. Please help!
Thanks
12 REPLIES 12
AndrewL
@Fari5: In order to locate your Gear S3 please navigate to the Galaxy Wearables app on your S9+, tap on 'Find My Watch' and hit 'Start'. If your watch is outside Bluetooth range then you can select 'Get Location' to obtain the address and location, or 'Set Security' to remotely manage the device. Hope this helps.
Fari5
Hey thanks. I will try this now and tell you the outcome
Fari5
I cant see these options Find My Watch and others. I only have this.
Fari5
Please helppp
AndrewL
Did you disconnect your watch from your phone prior to losing it, @Fari5? If you scroll down to Gear S3 on the 'Pick Your Device' screen and select it, do you see any available options?
Fari5
I opened this
AndrewL
If you tap the 3 lines in the top left corner, do you see the 'Find my Watch' option here?
Fari5
No
Fari5
I have here, but I cant press itScreenshot_20190708-142518_Gear S PlugIn.jpg
