gear fit 2 display problems
(Topic created on: 14-09-2017 07:28 PM)
I have this problem too
busa100
hi only had the gear fit 2 since the 12th September and the display started to go brown today then had lines in it, comes on after a few min then turns back off. it's still vibrates so think it's still receiving notifications.
any suggestions please.
1 REPLY 1
BandOfBrothers
If a soft reboot by turning the device Off and On does not help or a factory reset then if this was my device i'd be wanting to swap it for a new one due to how new it is.
Usually a 30 day swap out is relevant if purchase from a shop.
Please check where you acquired it from.
Good luck.
:smiling-face:
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
