Help Icon X damage
(Topic created on: 15-09-2017 11:54 PM)
Noemi88
Hi, my son has beaten my icon X with tooth and carried in mouth.
it could be possible that he has damaged the batteries and some toxic material got out?
however the icon X only has some little teeth signs on it and it works normally.
thank you
3 REPLIES 3
BandOfBrothers
Samsung Members Star ★★
Unfortunately if the earbud is damaged by the way you describe it wouldn't be covered under the Manufacturing Warranty @Noemi88
If the unit was punctured by a tooth you should be able to see that visibly and if so then seek medical attention for your son just to be safe for his health.
If it wasn't breached then you've now got a very unique earbud with your sons tooth print in.
Plesse do keep them out of reach of youngsters so stop this and choking hazards.
:smiling-face:
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Noemi88
Thank You!
But it could be possible that the unit lost  any liquid material? Such as battery electrolyte?
I can't see anything.
BandOfBrothers
You would really need to take it to a Samsung Service Location to be looked over.
