keep samsung health active while running
(Topic created on: 01-02-2025 09:32 PM)
jehora
I have a samsung watch 6 and use the Samsung health app to record my runs. After an update, the watch switches back from the Samsung health app to the main watch face within a few minutes. Before it stayed in the Samsung health app without problems. Fortunately, Samsung health runs in the background, but it is not particularly optimal.
Does anyone know a solution to this problem?
The watch is set to "Always on Display".
4 REPLIES 4
Alexbobo
Pioneer
Its not the always on display problem.
Try force stop the app.
Toggle on the activities to detect.
Let me know if it works
smg1
Troubleshooter
This is a fixed in a setting on the watch itself.
I'll try and explain how to find this.
On your watch, start and activity, such as running.
Immediately select Settings
Scroll down, quite a way down until you see Screen Always On. Make sure this is toggled on.
This should solve your issue.
But be aware this setting uses more battery.
jehora
Notitications was not turned om from Samsung Health app om watch. When I did it solved the problem!
jehora
Notitications was not turned om from Samsung Health app on watch. When I did it solved the problem!
