Earbuds connecting as separate devices
(Topic created on: 23-04-2020 12:30 PM)
SimplyDLT
Hi. My earbuds which I got and use with my samsung s10 have stopped connecting together and my phone is now recognising them as individual devices. Any advice greatly appreciated
4 REPLIES 4
Jonathan1205
Samsung Helper
Hi simplyDLT, Sorry to hear that you're having issues with your Galaxy Buds. Here's a few things that you can try:
1. Place both buds in the charging case for 10-15 seconds, then place them back in your ears.
2. Disable Bluetooth on the connected mobile device for around 20 seconds then re-enable it.
3. Open the Galaxy Wearables app > About Earbuds > Reset Earbuds
If the issue persists then I recommend visiting a Samsung Support Centre where an engineer can inspect the buds for you. To find your nearest one please check the link below, select 'Mobile Device > Phones, Tablets and Wearables' and enter your post code.
http://www.samsung.com/uk/support/servicelocation/
FlorieJoy
Samsung Helper
Thanks for the info on this, really helpful.
Jonathan1205
Samsung Helper
No worries
Ashley77
Pioneer
I have done all this multiple times, but my phone is recognising the Buds as 2 separate devices! Bud L is one device, and Bud R is another device.
