Go to solution Solved
Double tap to wake up
(Topic created on: 28-09-2018 10:20 PM)
Marv147us
When my watch is set to aod mode and wake up gesture off You cant wake screen up by tapping is this normal or is it a setting issue
TracyR
Troubleshooter
Hey @Marv147us
There isn't a setting to enable to the watch to wake up upone tapping the screen.
Say "hello!" and
Introduce Yourself, or virtually hangout in the Samsung Lounge
4 REPLIES 4
TracyR
Troubleshooter
Hey @Marv147us
Say "hello!" and
Marv147us
Thanks mate just wondered if it was a problem with watch
Cad08
My watch turns on all the time!!  Workouts randomly start, is there a way for it to stay off until I press a button or tap it?  I am constantly stopping workouts I am not doing!!  Thank you
AndrewL
@Cad08: It sounds like you might have the device set up to automatically detect workouts. With this in mind, open S Health on your watch > Rotate the bezel clockwise and tap 'Settings' > Workout Detection > Disable this option if it is active. Hope this helps.
