Double tap earbud edge not working on buds2 pro
(Topic created on: 13-03-2024 05:09 AM)
Abhi1111
If anyone have the same issue. Volume control doesn't change.
4 REPLIES 4
BandOfBrothers
Samsung Members Star ★★
Hi @Abhi1111
This is in the labs section I believe which is experimental.
This can be a hit and miss way of turning the sound up and down. You have to be pretty accurate with double tapping on the inner edge of the earbud next to the earlobe.
I've found that sometimes actually tapping that part of the ear, or top of the ear ,or bottom of my cheek / hawline can work too.
If nothing is working it's then either that the earbud isn't seated correctly so try adjusting it in your ear ,and or turn the feature Off and then back On in the labs section @Abhi1111
In the end I personally chose the long hold on left and right earbud to change the volume as this js much more consistent.
If I can be of any further help then please don't hesitate to ask.  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Abhi1111
Thanks for your valuable reply 👍
BandOfBrothers
You're very welcome @Abhi1111  👍
TechZilla
Mine is random, it is a beta labs experimental feature so I don't expect it to work constantly and with the shape of my inner ear I can imagine that my ears interfere with the edge touching.
TechZilla - Samsung Members Star
