Buds Pro low volume
(Topic created on: 03-03-2021 11:36 PM)
Kamsung
Navigator
Hi. I love the new buds pro however the volume seems a lot lower than when I first used them on the same tracks I listen to. Tried adjusting the volume using the touch pads on the ear phones. Didnt help. Any suggestions? Btw I've not got used to it as my partner said the same thing. They are a lot lower as I over 3 quarters was too loud. Now full doesn't seem that loud
4 REPLIES 4
Edgie70
Troubleshooter
Go to developers options and turn on " disable absolute volume " turn media volume on phone to minimum , press volume on bud to maximum , then adjust volume up on phone !
Kamsung
Navigator
I tried that. weird thing is I opened the ebay app then the volume went flying up.
Edgie70
Troubleshooter
Close all apps and try it
Kamsung
Navigator
thanks for your help bud
