WWE Network App QN94A Neo QLED 4K HDR Smart TV (2021)
(Topic created on: 04-10-2021 11:09 AM)
WWEADDICT4LIFE
i See on WWE.com that the app works on samsung smart tvs 2017 and newer tvs upwards and yet on my new QN94A Neo QLED 4K HDR Smart TV (2021) this app is nowhere to be seen and will it be on there at some point in the uk store as my previous tv had it on the store
Many Thanks
A
3 REPLIES 3
TessM
Mastermind
Hey @WWEADDICT4LIFE ,
you are right that seems to be compatible on 2017 TVs and onwards. Can you please check what software version are your TVs currently running on? You can find this information by heading into the Settings> Support> About this TV or Contact Samsung.
WWEADDICT4LIFE
this is my tvs info
Product Information
- Model Code: QE50QN94AATXXU
- Serial Number: ODPS3SIR900587T
- Software Version: T-NKM2DEUC-1805.4, BT - S
- Status Code: 30401_Z_Z
- Sub-micom Version: T-NM2INTV-1005
WWEADDICT4LIFE
just wondered is it not possible to just add the wwe network to the samsung store on the brand new above tvs it surely cant be that hard to add and i would really like it on my new tv
many thanks
A
