Go to solution Solved
Where to plug in a Fire Stick
(Topic created on: 02-12-2020 02:28 PM)
dereksimpson
I have a SUHD HDR 1,000 4K Ultra HD,Quantum Dot Smart TV 55” and a Amazon Prime Fire Stick  where  should I plug it in?
JAMES4578
Samsung Members Star ★★
An update to previous response as Amazon prime is now available  directly on SkyQ, HDR10+  or Dolby Vision  (on applicable sets) will not be supported on this platform though unlike the Tv apps. https://www.forbes.com/sites/johnarcher/2020/12/14/sky-q-and-now-tv-get-amazon-prime-video-support
6 REPLIES 6
Daveyboy123
Navigator
It just plugs into a hdmi port on the tv. Doesn’t matter really which one.
JAMES4578
Hi @dereksimpson  yes as @Daveyboy123  has said any  HDMI port should be fine.
Process pretty straightfoward but  shall include a quick guide here.   https://www.hellotech.com/guide/for/how-to-set-up-amazon-fire-stick
dereksimpson
I have a SKY+ box connected and it is not showing on SKY.
JAMES4578
Hi @dereksimpson Customers  will need to change the input to access the services on the Firestick connection.  It will not show on the Sky connection.  For instance if the Sky Box is connected to HDMI1  users  would need to select the appopriate input for the Firestick  whether it be 2 ,3 or 4 depending on your TV.
on the other hand if you are specifically referring to Amazon Prime it is available as an app on Samsung Smart Tvs, it is not integrated into the Sky service in the same way Netflix is, though only available via SkyQ.   Sky though has no deal with Prime on any of its platforms.
Various ways of accesssing Prime here:  https://www.pocket-lint.com/tv/news/amazon/139223-how-to-watch-amazon-prime-video-on-tv-your-complet...
Netflix on Skyq for applicable customers:  https://www.sky.com/help/articles/netflix-faqs
JAMES4578
dereksimpson
Thank You and at last SKY have seen the light!!
