Go to solution Solved
Recording from a DU8500 tv
(Topic created on: 20-03-2025 02:35 PM)
Graham2025
Hi
Can anyone tell me if it is possible to record directly onto a hard drive or memory stick, from a DU8500 tv
JAMES4578
Samsung Members Star ★★
Yes,you would be able to connect a Freeview Recorder. Some examples here https://www.cordbusters.co.uk/best-freeview-boxes-recorders-tv/
5 REPLIES 5
JAMES4578
Hi @Graham2025 Welcome to the Samsung Community :smiling-face:   It appears that this model does not have a record function (reviews mention this)  as tends to be the case with lower end Tv's.
Genweral guide here but dependent on model/region   https://www.samsung.com/ae/support/tv-audio-video/set-up-and-record-programs-on-a-samsung-tv/
Graham2025
Thanks James for such a helpful reply. You're right that this model does not have the recording function. I wonder whether it's possible to use an external pvr?
JAMES4578
Graham2025
Thanks James
I'll have a go at connecting a recorder. I may need help then with accessing it through my tv.
Thanks again.
JAMES4578
Oh right, no problem. Just  ensure you are on right source but can give further advice if needed.
