Watching a channel but sound from another channel?
(Topic created on: 24-09-2023 03:15 PM)
I have this problem too
Vinny74
I’m watching bbc1. But the sound is from channel &when I choose another channel (say 35) it still has the sound from channel 5?
any help!!!
7 REPLIES 7
JAMES4578
Samsung Members Star ★★
@Vinny74  Ensure you have the latest firmware, if not can be downloaded to USB and upated that way. https://www.samsung.com/uk/tvs/  However you may need to reboot the TV and any external devices you are using.  unplug for at least a minute before trying again.  If that does not work try a Factory Reset.
Spencer bloke
My Samsung TV has just done this too, I did a full reset to remedy it.
however it’s very disconcerting as it’s only been set up two days. Hopefully it’s now sorted because resetting isn’t a fix that’s acceptable if it happens again. Bottom line things have hiccups however it shouldn’t happen at all on a TV of this price.
Lunch
Same thing here on a new Samsung TV. Only thing that works is to factory reset and reenter all passwords and preferences. Very annoying and I can't find a solution anywhere.
Lunch
Have had this TV for 6 months, happens about once a week.  Very annoying that there isn't a fix for it
Lunch
I chatted with Samsung. They suggested unplugging the TV from the wall or power strip for at least 1 minute to reset the 'glitch'. It's annoying but less than a whole reset.  It has happened twice since and it has worked each time.
PaulTelly
Worked for us, thanks very much. Let's hope it continues to work.
snara
This is very annoying, as when it happens I have to make sure I am not crazy!  Unplugging from the wall seems to re-set it for awhile but the issue comes back.  Luckily I do not watch much local TV and mostly stream where this is not an issue.
