30-05-2020 07:33 PM in
TVHello community,
I have a samsung UE46ES5500 TV (which I bought 8 years ago), since 1 year I started noticing some pixel bars on the right edge of the screen in red color. It evolved now and I have a black band starting from screen right edge (band width is approx. 10 pixels), and the red pixel bars moved a little bit inside the screen. It's a bit hard to explain so I attached some pictures as they are better than words.
I am a bit afraid that one day my TV will refuse to switch on so I wanted to know the root cause of this issue.
Thank you in advance for your support.
Best Regards,
Yassir
31-05-2020 12:31 PM in
TV31-05-2020 03:04 PM in
TVHello Andrew,
Thank you for your feedback.
The problem is happening with all sources (and even when playing videos from a USB stick). I ran the picture test as advised and it's still there, so I guess I will need to contact a support center for this...
Thanks again.
Best Regards,
Yassir
30-08-2021 04:31 PM in
TVI am having a similar problem as you but my vertical black/shaded band is center-right and a small band that is center-left on my screen. I bought my Samsung TV - Samsung - 55" Class - LED - NU7100 Series on 4/20/2018 and I can't believe I'm having problems already! I only bought a 2 year extended warranty so I guess shame on me for having faith that Samsung would be reliable and that I wouldn't need the warranty extended past that 2 years. I DEFINITELY will never buy a Samsung TV again and will be going with Sony from here on out.
