a month ago in
TVAlmost 4 months of ownership and the TV now runs worse than when I first got it! Numerous issues, the majority I think can be put down to connectivity. Running on latest firmware (1460.9)
I've Samsung UE48JU6400 which I've never had any issues with a still works perfectly, other than a couple of "light" spots on the screen due to lamp issues I think , this being the reason I replaced it as my main TV and went with another Samsung but it seems with the newer models no QA is done to ensure they are at least as reliable as the old ones.
a month ago in
TV
oh my...
have this reported with Samsung Support to have this fixed
https://www.samsung.com/uk/support/contact/
4 weeks ago in
TVNot yet no. Done (as I have every month since I bought it in September) a factory reset which seems to have solved some of the issues, but I'm staying away from Device Care and Ambient mode at the moment so as to try and avoid having to do another.
Reason I've not raised with Samsung yet is, I've a Sky Fibre router which currently has a known DHCP issue when you have a high number of devices on the same network. I've wired the TV via ethernet and given it a fixed IP address to hopefully mitigate this, but hoping for a permanent firmware update of the router (last update sometime in Feb) to see if that irons out any of the issues before going to Samsung, who could just just say it's a know issue with my ISP provided router and to speak to Sky.
Posted on here just to see if anybody was having any similar issues and if there was a simple way of resolving.
Still stand by my point on QA though, when a five year old Samsung I've never had to factory reset is more reliable even give the router issues mentioned above) in it's features than a 2020 model, something is not quite right.
