Usual volume is now too low HW-T450
(Topic created on: 24-11-2020 07:48 AM)
kevinh89
Hi,
I got a UA65TU8500SXNZ TV connected to a sound bar HW-T450/XY and its subwoofer PS-WT45T.
I usually use the audio output to the sound bar (optical) on a volume of 10.
Since today, volume 10 sound feels very quiet. Navigating the menu, the feedback sound is way quieter. I gotta take it to 25 to sound like it used to. The TV, soundbar and woofer are all 3 months old.
I tried unplugging it from the wall and plugging it back on with no success.
I also tried resetting all audio settings to default.
I also tried removing pairing between TV and soundbar, which I dont know when it happened because from the very begining I chose to use the optic as connection to the soundbar.
@ChrisM maybe you know any tips?
2 REPLIES 2
kevinh89
I updated the firmware of the soundbar to the latest and no luck.
kevinh89
