Using USB 3.0 1TB USB HDD with Series 9
(Topic created on: 21-10-2021 04:18 PM)
Members_ACI0NpP
To enable using Timeshift and recording, I've attached a USB 3.0 HDD to my Series 9 TV, it has a 1TB capacity.
Even though I have formatted the drive, I get the message... use a higher speed external drive. But it doesn't say what speed I should have as minimum.
Does anyone know what I should be using?
Thanks
2 REPLIES 2
AndrewL
@Members_ACI0NpP: The user manual states the following: "A USB hard drive with a speed of 5,400 rpm or above is recommended. However, RAID-type USB hard drives and USB memory sticks are not supported." I hope this helps.
Members_ACI0NpP
Thank you.
