VRR flicker and lines on bottom edge of the screen Q77C 65'
(Topic created on: 15-04-2025 01:04 PM)
CasperQ98
Hello,
I have Samsung Q77C 65' 120HZ and PS5/Series X. Since update 1410/20 if I remember correctly there has been a major problem with Game Mode.
VRR flickers a lot during every stutter and FPS drop in game under 48Hz. Even when playing in 30fps games vrr flickers. Also there is a big ghosting effect on objects in games like a white lines around them.
The lasy problem is that when im playing theres a moving line at the bottom edge of the screen (usually green or red). What's strange it disappears after i turn on motion plus (which i have). Colors in HDR are oversaturated.
Anyone with similar problem? Tizen update didnt fix anything...
1 REPLY 1
rileylovetech
Voyager
You play games what console
