09-03-2022 04:06 PM - last edited 09-03-2022 04:09 PM ) in
TVA few days ago all the freeview HD channels have suddenly disappeared. Only TV Freesat available. Seems like other have same problem.
Tried auto scan/turn off and on/reset/ with and without aerial plugged in/ socket unplugged and replugged etc - NO DIFFERENCE.
Called satellite/aerial/cable engineer who spend lots of time checking block aerial and signal and confirmed with his device that HD coming to socket. problem with TV. TV not accepting HD channels.
Called Samsung support- somebody from Philippines called (hard to understand). He went through remote management (did same as me and engineer)
- OUTCOME. Nothing wrong with TV ...go back to aerial engineer !!!
Still without HD and other freeview channels...what to do.
Call Samsung again or engineer?????
Anyone else with same issue?
09-03-2022 04:30 PM in
TV09-03-2022 04:44 PM - last edited 09-03-2022 04:45 PM ) in
TV@golders1 has already tried auto tuning with aerial disconnected and connected again. Are there any known reception problems in the area, check here https://www.freeview.co.uk/freeview-channel-checker Has a Manual scan been attempted as shown here https://www.bbc.co.uk/reception/help-guides/freeview/manual-retuning-to-restore-reception-or-missing...
If all troubleshooting has been tried including a factory reset and no known issue in area would suggest a problem with the aerial.
One Ui 4.0,Android 12 Official Version.
09-03-2022 04:50 PM in
TVTried many times but no improvement.
09-03-2022 04:51 PM in
TVHi James,
Thanks for input.
No issues with freeview after checking many times.
But not tried manual tuning. Will give it a shot.
09-03-2022 04:53 PM in
TV@golders1 oh right, thanks for confirming. No guarantee but hopefully manual tuning might make a difference.
09-03-2022 05:01 PM in
TVAfter reading freeview website, was wondering whether a separate Freeview box is needed. That said, this tv is advertised as having built freeview HD. Have had freeview HD on this tv since 2018.
All changed after the storms hence calling out the aerial company who double checked all the aerials on each block of flats.
09-03-2022 05:34 PM - last edited 09-03-2022 05:36 PM ) in
TV@golders1 The Built in Freeview should be fine,though some may prefer external Boxes. If aerial is the issue will not provide a solution,though realise company have not detected a fault. Are you up to date with Firmware,latest is 1300.3 https://www.samsung.com/uk/support/model/UE65MU7000TXXU/
10-03-2022 11:47 AM in
TVFirmware up to date and manual tuning did not resolve issue.
Only thing left is to go back to aerial engineers who did seem very very adamant the HD signal was being received up the wall socket which they tested in front of me. Stumped for now!
10-03-2022 12:40 PM in
TVI do not work for Samsung or make Samsung Products but provide independent advice and valuable contributions.
