Wrong Channel Numbers/Order
(Topic created on: 30-12-2024 12:17 PM)
Luke A
2024 Samsung QN85D, set up in correct region (London), connected to aerial, no tv box. Freeview channels seem to be numbered wrongly, as shown in photos. Have cleared channels and retuned, and have done a factory reset, with no luck. Any advice aside from re-numbering them all manually? Thanks in advance.
6 REPLIES 6
SocietyGirl
Hi there,
Has this just happened on its' own or did you do anything to get it to happen? Is postcode correct?
Thanks,
Say hi to us on socials -  @SamsungUK
Luke A
Hi, thanks for the reply. It is a brand new tv, and has been this way since setup. Yes, double checked the post code.
Thanks
SocietyGirl
Could you please dm me a photo of the full model code? It'll be on the back of the TV or in settings. Cheers!
Luke A
DM sent!
Thanks.
a_mcn
I have just bought a Q60D 43 inch for my Mother in law and have exactly the same issue.
interested to hear if you find a solution
Members_CpaWN1z
Yes, same problem here. Brand new telly in East yorkshire
