UE60KU6070UXZG UHD4K LED TV - problem with saving picture settings
(Topic created on: 09-02-2017 10:51 AM)
allen7
Yesterday i've bought ''Samsung UE60KU6070'' TV..
By picture settings i have few options
1.standard (default)
2.dynamic
3.natural
4.movie
It stands on Standard,and when i go to Expert Settings (cuz i wanna little higher brighness) after few seconds picture go back to default settings...i was trying to google the problem and i saw that i need to go to :
system-expert settings-usage mode...and there i should switch from retail mode to home mode,but the problem is,it is already on home mode...
but if i choose dynamic picture and change settings in dynamic picture (like brightness,contrast etc) then i t works,it doesnt go back to default settings...
but personaly i like standard picture more,so i wanna use that option and then ''play'' with settings...where is the problem,and what did i do wrong?
thank you so much for your help
1 REPLY 1
KellyM
Helping Hand
Hi there @allen7,
The model code provided doesn't appear to be a UK version, where did you buy your TV from?
What software is your TV running on at the moment? Go to: Settings > Support > Contact Samsung.
