Gamma setting
(Topic created on: 03-04-2025 12:31 PM)
Ginga_p
Hotshot
After the last update for the qn95b i have been having slight issues with the picture quality degrading from pre update gone through the usual reset. Eco off ect. But er ing to the gamma settings but this bit im not sure if certain setting wont make the most of hdr?
G G
2 REPLIES 2
JAMES4578
Samsung Members Star ★★
@Ginga_p  I think it is best to experiment though Gamma at highest level  tends to result in a Darker picture.  Have you tried other adjustments and different Picture Modes , think it is usually best with Intelligent Mode disabled.  obviously you have tried the Facory Reset which sometimes helps.
Ginga_p
Hotshot
Always have intelligent mode off find it abit messy and unpredictable. Thanks for the advice.
Find 2.2 slightly better than bt.1886 but reading up 2.2 is more designed for sd content but the information is very confusing.
G G
