Go to solution Solved
UE43M5520 43" Smart LED TV not recognising Toshiba Canvio basics USB3.0 Hard Drive
(Topic created on: 12-02-2018 07:36 PM)
sklitch
Hi, simply as above. Tried both USB ports, switched TV to standby and back on whilst the Hard drive is plugged in and nothing. It just says no USB device connected. I thought I had confirmed (elsewhere) that this drive was compatible.
Can anyone help?
TIA
2 Solutions
sklitch
Thanks James. The cable solved the problem. The TV now recognises the hard drive and we can record (I'm not sure if it was a power problem or a cable problem as I have only plugged in the HD USB and it worked straight away, no need to plug the other USB in!). The problem we have now, which I have read is an issue, is that we can't record one channel and watch another and when the TV is on stand-by, it won't record either. I believe the solution is to update the TV's firmware. I will check  the version we have and investigate how this is done. Thanks for your advice.
JAMES4578
Samsung Members Star ★★
@sklitchwrote:
OK, done the update. It still won't record a different channel to what we are watching. It just overrides it and changes to the scheduled programme. Not tried recording with the TV on standby but if this didn't work I don't hold out much hope. Any ideas?
TIA
I've checked a few sites and specifications state this model has only one tuner, you would need dual tuner to record different channel.  However does rule out them being incorrect.  In any case as there is also the standby issue I would do a factory reset      ( Settings Reset- Settings -Support- Self Diagnosis- Reset,  Smart Hub Reset -Settings- Support- Self Diagnosis- Reset Smart Hub )  and turn off auto tuning.
12 REPLIES 12
paul1111
Hotshot
Can anyone help?
TIA
Faulty TV send back and get one that does work.
AntS
Hi @sklitch. :robothappy:
What format is your drive formatted to? And are you able to test another USB device or drive with the TV?
sklitch
I thought the drive was plug & play so would format itself when plugged in. I have done some more research and it may be the single USB port isn't strong enough to power the drive. i have orderded a y cable splitter to see if plugging it into both USB ports will work. I am yet to try a different USB device as I understand anything on a stick will be deleted when it formats for the TV and I don't have a blank stick to use . Not giving up yet and certainly not sending the TV back!
JAMES4578
Certainly try and see if cable splitter makes a difference, though imagined the port would be powerful enough. I've checked up on the drive and whilst it says formatted during manufacturing process,should you wish to format suggests there may be problems with FAT system and recommends NFTS.  It may be wise to do a format in any case. https://www.toshiba-storage.com/wp-content/uploads/2018/01/UM_Canvio_Basics.pdf   You could check you have the latest firmware installed which is  1153.1  http://www.samsung.com/uk/support/model/UE43M5520AKXXU      Would be a good idea to check another device at some point if still issues as  @AntS  suggests.
The only thing is I've noticed some having problems with USB 3.0 devices on a US site, though does say 2.0 compatible. Noticed there can be an issue with hard drives with 3.0 GB or greater capacity on Tv's and advice is to repartition , however may not be relevant in your case.
sklitch
JAMES4578
No problem Sklitch, glad your hard drive issue issue at least seems resolved.
sklitch
Seems our firmware version is 1151 and it won't update through the TV. The link you gave me shows the version I need but how do I get the update onto the TV? Sorry to keep on with the questions.
sklitch
Sorry James, I was being thick. I can now see there is a d/l manual with the update. I will sort it tomorrow. Thanks again
JAMES4578
That's ok, yeah you download  file to usb  stick and update that way. Once you insert into Tv go to software update ,ensure you're updating via USB.
