12-02-2018 09:59 AM in
TVJust bought tv , plugged power cable into back of tv and it fits so loose you can barley touch it and it will fall out.... it stays in and works fine but bothers me if you even touch chord it will fall out. Tv model is ue55mu9000
31-12-2018 04:31 AM in
TVI have the same issue, did you ever figure out how to fix it?
06-06-2019 01:38 AM in
TVSame problem here too since it came out of the box. Any movement will make it fall out. It's too loose to support its own weight. I have it duct taped but that is only slightly helpful. I would love to know a better fix.
28-04-2020 03:20 PM in
TVI have a 27" Samsung monitor/TV receiver that I've had since approximately 2009, this wasn't an issue for a long time, but is now a big issue. Bought a new power cord to see if that would fix it, but I think it's the connector portion of the TV. Has anyone gotten a response from Samsung?
15-11-2020 06:14 PM in
TVDid you ever fix the problem?
08-12-2020 02:26 AM in
TVI'm having the same issue with a brand new TV and can't find anything else on this. Did you end up fixing the issue?
09-12-2020 02:42 PM in
TVPush the plug with force.
25-08-2021 03:04 PM in
TVOMG. I've been propping the plug in with a pen tube and recently with a 10" screw driver. Just used force and it clicked into place. I guess the little plastic ring at the end has to get past the reciever. Sometimes it gets hot when propping it in since it's barely making contact. So, push it in harder than you normally would!
