UE40MU6172 Motion laggy stutter judder issue
(Topic created on: 18-12-2017 02:48 PM)
Deyan601
Hello all , my Smart tv is model UE40MU6172 i use  motion plus feature , judder reduction to max 10 and with this option picture motion was perfect smooth fluid  without any jittery or stutter movement , but after update the new firmware version 1151.1 after the factory resset  even when i turn judder reduction feature the motion movement is not that smooth as on prevision firmware  its visible stutter and slowdowns on the movement of the picture in time by time. So far i try swap the HDMI cable but that didnt slove the problem. Please someone if face that issue on the same model tv or familiar to it please  to help me to slove that problem. The problem is visible even on youtube videos 60fps
3 REPLIES 3
aliastefan
I have same problem on my SAMSUNG UE40MU6172. When I connect my laptop through wireless display TV Samsung, constantly when I playing movies, the image and the sound are easily freezing. Please, help us if someone know the resolution. In other, I will return the TV. Thx.
paul1277
Black Belt
Have you reported the issue to your retailer because it could be a fault and they may be aware of it. Also it's useful to have any faults logged with the retailer as soon as they appear. If it's new may be best to ask for a replacement.
valleyboy22
Voyager
I have recently bought a ue55MU6500 curved tv and get a similar problem. I have tried custom motion plus settings, but the lower you goon there the lower the picture quality goes. I have asked loads of times for advice but not joy, so good luck.
