Go to solution Solved
UE32T53000 - lost wifi connection
(Topic created on: 25-07-2021 06:40 PM)
smck75
Hi,
Model: UE32T53000CKXXU
I've had this TV since April, however this week the TV stopped connecting to the Home Wifi network (Virgin) and I no longer have any smart function/access to Netflix, Amazon apps etc.
After carrying out a factory reset, the TV is able to find the Home Network during the new setup process, but it is unable to establish a connection and I am left with only access to terrestrial channels from the ariel cable.  I am still able to access the smart functions/apps when connected through a wired connection, but not through wireless.
How do I fix this?
JAMES4578
Samsung Members Star ★★
Hi  @smck75 ,
You can you try a soft reset by holding the power button in for around 5 seconds or until the logo appears.   If no effect unplug the Tv  for a few minutes and rebooting router by unplugging from mains may have some effect.  Another idea is to change the DNS settings from Automatic  it to 8.8.8.8  and 8.8.4.4   (the Google servers).  Go to  Network-Network Settings-DNS Settings.   There are also other alternatives such as Open DNS  .
Primary DNS server address: 208.67.222.222
Secondary DNS server address: 208.67.220.220  See more here: https://www.broadbandgenie.co.uk/broadband/help/best-free-public-DNS-server
2 REPLIES 2
JAMES4578
Hi  @smck75 ,
James Lang
Hi ,
I had the same problem and I was able to fix it by trying one of the methods mentioned here: https://www.techieinsider.com/samsung-tv-wont-connect-to-wi-fi-fix/
Try and let me know if these solutions worked for you.
