UA32N5300AR, no airplay option in settings menu
(Topic created on: 28-06-2019 07:13 PM)
memakda
Hi
I bought this TV specifically because of Apple Airplay
Firmware update to 1260.8
Apple tv app is there but I don't see any options for Air Play.
Also my Iphone XR with IOS 10.3 does not pick up the TV for screen mirror
Please help
3 REPLIES 3
AndrewL
@memakda: Hi there. Sadly the only information available to us on this forum is for UK and Irish models, which this doesn't appear to be, therefore we recommend reaching out to Samsung Support in your region for further details on the update. Apologies for any inconvenience this might cause you.
cgabrielgt
Hi.
I would like to know if you can solve the problem. I have a samsung of different model and I have the same problem, the airplay option does not appear in the menu of the tv and it does not work
memakda
@cgabrielgt wrote:
Hi.
Option not supported in South Africa for 5 series models. Only 7 series. I returned the TV.
