TV Visual Not Working, audio is fine. See screenshot below, I have unplugged and restarted
(Topic created on: 15-06-2020 08:49 PM)
Olu007
11 REPLIES 11
ChrisM
SuperStar
Hi @Olu007
Could we take the full model code of your TV please? You can find this on a label at the back of the TV.
Olu007
Hi Chris,
Thanks for your response, model no is LT24D390SW/XU
CarlH
Thanks, @Olu007. Is that picture of you TV with it on a black screen? Can you try a Picture Test and see if the issue persists? To do this, press Settings/ Menu on the remote and go to Support > Self Diagnosis > Start Picture Test.
Olu007
Yes, that is a picture of the television. The TV is not responding to the remote control, not displaying any visuals.
CarlH
Do you have any external devices connected to the TV?
Olu007
I have disconnected cable decoder connected to it and restarted but still having same issues.
CarlH
Olu007
I purchased in 2016 @ Currys
CarlH
It mighyt be best if an engineer inspoects this, @Olu007. This link will direct you to the closest Service Centre in your area. Hope this helps.
