15-07-2024 10:33 PM
Hei ,
Everyone.
I am facing the problem that my smart Samsung smart tv turn off every 10 seconds. That happend from the last month but not too frequent. But from last week TV trun off every 10 second. I deattached every cable HDMI , google chromcast device. Everything. Checked every wire connection. Changed postion of electricity. Setting everthinh is off. Sleep time, energy savingmood Everything.
But still facing this problem.
What can can i do.
Someone said that thais can be capacitor issue
Any expert can explain what can i do.
With my Best regards
Abdul
16-07-2024 12:10 AM - last edited 16-07-2024 12:11 AM
Hi @Abdulrph You have not mentioned the model but check you have the latest firmware as sometimes the issue can be caused by outdated software.
By any chance are you using a Power surge, if you have a green light on the surge part should be ok. However if so try plugging directly into a socket to rule that out. some further advice here https://www.samsung.com/ae/support/tv-audio-video/what-to-do-if-your-samsung-tv-auto-resets/#:~:text...
Another possible fix though is to hold the Power Button on the Remote for 30 seconds till it hopefully Reboots,unplug from mains for 1 minute and try again. If no joy an idea to see if a flash reset will work:
Under the Samsung logo on the TV you have a small black button about 2-3cm in from the bottom edge. With the tv turned on
1. press the button at the logo for 5-10 seconds
2. Release the button
3. press the Power button on the TV Remote for 5-10 seconds. Tv goes black and then restarts after a while.
otherwise would need a repair, can contact Samsung support if you think it is worthwhile https://www.samsung.com/uk/support/contact/
