Freesat problems
(Topic created on: 15-07-2024 11:39 PM)
JamieA81
Hi, I’ve recently purchased a new tv - QE55QN88C. Prior to this I used a Freesat box to receive channels with no issues but I tried plugging the dish cables directly into he tv and can get no channels to work. I contacted Samsung support who suggested I need to get an engineer to come out as it was showing signal quality and strength around 40-50% and a bit error level of around 130. Is there anything I can do before I get someone out to look at this? The dish has been up for several years so likely and older lnb
8 REPLIES 8
arkih
Did you choose the same satellites like on your freebox??
JamieA81
Yes same satellites, tried so many settings but no success!
arkih
Is your freesat box an HD one??
arkih
I had to put a bigger dish to get a stronger signal to watch HD channels.
arkih
Check if your old converter is full HD.
arkih
The most annoying thing on my Samsung is that I need to switch freeview or freesat aerisl in options depending on what I want to watch.
JamieA81
It’s a full hd box and all the channels had no issues previously. We haven’t got an aerial installed so just through the dish
Nala5
I had Sky Q which was proving expensive so I wanted to switch to Freesat. It was quite difficult to establish whether the TV had the necessary satellite receiver built in but it had a connection point so I took a chance and replaced the lnb on the dish (£10 from Amazon). I used the same cable and the TV's built in scanner to locate the channels. All good but after a while the TV started pixelating and signals were dropping. After much research I chanced upon a site that said the UK is covered by Astra 2 28.2E whereas the TV's default satellite was Astra 2 19.2E. Made the necessary changes on the TV's scanning settings (you select the satellite from a drop down list) and bingo, all good. I hope this helps someone with similar issues
