Tv stand screws for UE49NU7100KXXU model
(Topic created on: 28-04-2020 08:43 AM)
Ggwilkinson
I need to buy some screws for the base stand of my TV, the model number listed above. I just need some help finding the correct ones, can someone point me in the right direction? Thank you!
5 REPLIES 5
TessM
Mastermind
Afternoon @Ggwilkinson ,
are you able to tell me when and where did you purchase the TV? Weren't the screws included in the box?
Ggwilkinson
Hi Tess, they are not but I bought it a year ago and haven't used the stand so I have perhaps misplaced them. Is there a quick link to order the correct ones? Thanks
TessM
Mastermind
That is fine @Ggwilkinson . I would happily recommend the following retailers to get the screws to fit the TV stand:
http://www.4ourhouse.co.uk/
http://www.espares.co.uk/browse/ma596/samsung
http://www.partmaster.co.uk/samsung-parts/shop.pl
You should be able to find the right ones by introducing the TV model on the search box.
Ggwilkinson
Hi Tess,
When I search by UE49NU7100 the only results that are returned are the remote controls.
Do you happen to know which screws?
Thanks,
Georgie
AndrewL
@Ggwilkinson: In the user manual it simply states to refer to the assembly guide that was included with the TV, and doesn't mention the specs of the screws. Do you have access to the assembly guide?
